Author Topic: Criteque this trailer  (Read 787 times)
Offline fordtoy1
Re: Criteque this trailer
« Reply #30 on: January 20, 2018, 01:29:03 PM »
with a trailer that heavy you better use that at least twice a month or its not worth the money!
Offline jabberwoki
  • Doooh missed out
« Reply #31 on: January 27, 2018, 05:40:18 PM »
There is a very fine line between a hobby and a mental illness.
Does the need justify the want ? Or does the want suffice?
Offline Heiny57
« Reply #32 on: January 28, 2018, 10:33:37 AM »
I frequent an RV forum and that debate gets kicked around every 6 months or so. They get heated and no one ever wins.  Bslap  I use ST and keep them inflated and try not to drive over 65.
Wake Up America
If you can't fix it with a hammer, It must be electrical.
Online highland512
  • Member of NOMAAM
« Reply #33 on: January 31, 2018, 11:26:05 AM »
If I cant travel at highway speeds when traffic allows it because the tires are limiting factor its time for new tires. 16" is definitely the way to go, all of our trailers have 16" and I would never go back to anything else. Also, no chicom tires never ever never  flameon
-Matt
"I believe that the best possible social program is a job." -Ronald Regan
Offline jabberwoki
  • Doooh missed out
« Reply #34 on: January 31, 2018, 01:16:50 PM »
what tires do you.use?
Online highland512
  • Member of NOMAAM
« Reply #35 on: January 31, 2018, 03:22:31 PM »
The 12,000 lb bumper hitch has a set of trade in coopers
http://us.coopertire.com/tires/discoverer-ht3.aspx
The 20,000 lb Gooseneck has 8ea new firestone ht's on it.
https://www.firestonetire.com/tire/transforce-ht/lt265-75r16
I will say though most of the pooped trailer tires you see on the side of the road are most likely a result of overloading, neglect, or a tire that is old enough to vote.
-Matt
Offline Heiny57
« Reply #36 on: February 01, 2018, 02:22:17 PM »
I am limited in choices to a 14 inch tire on my Camper because of clearance issues. Most all 14” are Chicprap maypops. I limit my speed to give my F 150 a break and save a little fuel also. It’s amazing the difference 5 miles per hour makes at those speeds.
« Last Edit: February 01, 2018, 03:08:10 PM by Heiny57 »
Wake Up America
