Author Topic: I finally found a truck  (Read 2167 times)
Online skfarmer
Re: I finally found a truck
« Reply #45 on: August 01, 2017, 09:12:45 AM »
not a ford guy but i know a survivor when i see one. all the trucks of that vintage are used up around here. too much gravel and rust. i am sure it serves krusty just fine. it's a real truck.
« Reply #46 on: August 01, 2017, 10:02:24 AM »
True, you find most well preserved survivors in the south.
Offline platypus20
« Reply #47 on: August 01, 2017, 03:21:03 PM »
Mark, just wondering how the new truck is working out after a couple of weeks.
after readjusting the carb it now cold starts and idles smooth. Getting 13.6 mpg. There are a few little things that need attention but i am very happy with it!
Doing very well on gas mileage! Anything more than 10mpg is extra in a full size carbureted truck in my opinion!
Yeah, but it only makes 135 hp.
Ya, but that is all the HP Krusty needs so all is just fine.
We're talking the motorcycle's hp right??
jack
« Reply #48 on: August 01, 2017, 04:17:24 PM »
Nope, talking about his truck.
Offline lauver
  • King of Refurb's
  • PROTO BetR-Grip Whore
« Reply #49 on: August 15, 2017, 11:21:09 PM »
krusty,
I used to have an early 1980's Ford Bronco with a 3-speed manual trans & 302 engine.  This rig got 10 mpg no matter how I drove it or what I did to it.  I rebuilt the carb & distributor and tried every tune up trick in the book.  I even put taller tires on it.  Still 10mpg.
In the end I concluded the smog gear of that era must have been the problem... but who knows?
I eventually sold the Bronco and bought a Datsun early 1970's import-size pick up that pumped out 25-30mpg without fail.  I've been an import truck fan ever since.
At any rate, I'm glad you found a good old truck that meets your needs and puts a smile on your face.  And, as they say, KEEP ON TRUCKIN' :mr:
Member of PHARTS -  Perfect Handle Admiration, Restoration and Torturing Society
Offline krusty the clown
  • hell mann
  • former beer drinker and hell raiser
« Reply #50 on: August 16, 2017, 08:13:34 AM »
advancing the cam 3* usually does the trick th-wink
« Last Edit: August 28, 2017, 11:51:24 PM by lauver »
Offline nonhog
« Reply #51 on: August 16, 2017, 01:09:09 PM »
krusty,
Had an 81 FSB same set up. I must have had a lighter foot. 11 MPG! LOL Best ever was 14 MPG, funny thing I was hauling butt driving to a buddies thinking my gas mileage is going to be really bad. Odd? Maybe it wants to be run hard.
I'd consider another because I like the looks.
cursed with an eye for potential
Offline lauver
  • King of Refurb's
« Reply #52 on: August 28, 2017, 11:52:15 PM »
krusty,
Are you serious?  Did the Ford engineers deliberately retard it 3*?  If so, what did it accomplish besides poor mileage?
  • hell mann
« Reply #53 on: August 29, 2017, 09:14:40 AM »
krusty,
reduced cyl temp. It reduces NOx emissions. More dependable than EGR. Remember this was near the end of carbureted engines and stricter emissions standards than carbs were capable of. Manufacturers were reaching for straws...
  • hell mann
« Reply #54 on: August 29, 2017, 09:39:04 AM »
To be clear, it's not that the cam was retarded 3*. There is only so much to be gained by increasing overlap before you loose to much performance so they changed lobe centerline. We found in the field that increasing cam advance (old drag racing trick) would overcome it at less cost than replacing the cam. Besides at the time there wasn't near the selection of cams there is today.
Offline lauver
  • King of Refurb's
« Reply #55 on: August 29, 2017, 10:49:11 PM »
krusty,
Thanks for the info... makes sense.  Is one tooth on the cam gear 3 degrees"
  • hell mann
« Reply #56 on: August 30, 2017, 06:19:06 AM »
krusty,
no it takes an aftermarket degreeable cam gear. It's been years but if my memory is right they were moroso.
