Author Topic: It's frame cutting time.  (Read 910 times)
« on: September 23, 2017, 11:39:01 PM »
I installed a new lower control arm today on the Santa Fe. Got everything on no problem except for the last bolt.
The two front mount bolts go into the frame to a nut welded to the inside of the boxed frame.  Went to tighten the last
bolt and got it almost tight and 'snap'... the nut broke loose.
Fugged around for an hour trying toget the bolt to tighten or come out. It did neither.
Now the only thing I can do is drill a hole in the backside of the frame (if there's enough room to get a drill in there) just
big enough to get a socket in there to hold a nut.  Or cut the sides of a square, peel back a flap and weld the nut or
hold it with a socket then bend the flap back and weld it up.
Not looking forward to this but the only other option is a new front sub frame. ugg..
Had to take a break to stop myself from throwing things around the garage.  Also had to watch the hockey game.
It's just about 10:00pm but I gotta get it done tonight. Tomorrow's my birthday and the wife has plans for tomorrow.
Why's it always gotta be the last bolt?  why am I so soft in the middle but the rest of my life is so hard?
« Last Edit: September 23, 2017, 11:42:33 PM by brslk »
Re: It's frame cutting time.
« Reply #1 on: September 23, 2017, 11:40:53 PM »
I feel for you Brucypops.... and your right, there`s always one.
« Reply #2 on: September 24, 2017, 12:20:10 AM »
Maybe you can poke a drill hoe in the bottom of the rail and jam a screwdriver in there against the nut while you give it as many unga dungas with the air gun as it'll take. Godspeed.
« Reply #3 on: September 24, 2017, 12:55:02 AM »
Happy Bday bud.  thumbsup2 thumbsup2
 Sucks you gotta work on your birthday.
« Reply #4 on: September 24, 2017, 01:59:15 AM »
Thanks Curtis.
I came up with a new plan.  I'm just gonna drill through the existing hole right through to the backside of the frame and put a piece of 1/4" plate there with a nut.  The bolt will pass through both sides of the frame + plate and a washer with a nut.
I think this will be better than cutting and welding.
Not a lot of clearance on the backside between the frame and the oil pan.
Any one see a flaw in my plan?  or does it sound doable safety wise?   headscratch
« Reply #5 on: September 24, 2017, 02:01:30 AM »
Somebody's been watching Eric O at SMA.
Online Uncle Buck
« Reply #6 on: September 24, 2017, 08:22:15 AM »
Thanks Curtis.
I like this idea very much. Consider the idea UB endorsed!  :)) :))  BTW: HAPPY BIRTHDAY!
« Reply #7 on: September 24, 2017, 09:05:30 AM »
I'm with ya Bruce. Went to take a bumper of my truck yesterday and the last bolt sheared as well. Couple hours later and I called it a night.
Good luck!!
Offline J.A.F.E.
  • Alien Wizard Of Odd
  • Location: About 28000 Light Years from the Center of the Galaxy. At the moment.
« Reply #8 on: September 24, 2017, 12:11:43 PM »
Hope your UB endorsed plan went well. For the record sounds good to me too.
Happy birthday.
As alien as it gets.
Quote
Whatever he is it is seriously unpleasant.    No moral compass at all, no thoughts, no guilt or obligations beyond personal desires of the moment and no debts recognised if he already has the product.
Live long and 42.
« Reply #9 on: September 24, 2017, 10:54:50 PM »
Thanks for the birthday wishes.  I didn't get much done on the car today. I slept in and then the wife made me breakfast.  I puttered around the garage for a but and then had to get cleaned up. The wife took me out for dinner.  Now I'm too full to do anything but sit at the computer.
« Reply #10 on: September 24, 2017, 10:59:32 PM »
Well deserved I'm sure Bruce. All the best to you on this special day --
« Reply #11 on: September 25, 2017, 12:14:34 AM »
Thanks Ray.
Offline nonhog
« Reply #12 on: September 25, 2017, 05:42:54 PM »
Stirred up memories.
Hope it works as planned!
cursed with an eye for potential
« Reply #13 on: October 31, 2017, 01:31:24 AM »
I just realized I never did take pictures of it when finished.
I drilled through both sides of the frame and put a 1/4" plate on the back.  Ran a longer bolt through it with a nut
and lock washer on the end.
Hasn't fallen off and killed me yet.  I'll snap a pic next time I have the wheels off.
