The Toyota had this shorty little filter which an oil lube place said could be swapped out for the model used on the Ford V-8. A Fram PH8A.
Been using the larger filter ever since. Though I'm leaning toward switching to K&M as their filter has a 1" hex welded on the bottom so you can use a ratchet and socket to get it off. Less slipping that a banded wrench. 3X the cost, though.
Have seen this flexible magnet sheath that supposedly grabs steel particles that get through the media and holds them in the canister till you change the filter. You then swap the mag sheath over to the new filter. Got 240,000 miles without it, so, I've not sprung for it yet.
