Author Topic: Generator problems  (Read 644 times)
Offline m_fumich
  • Necromancer
Generator problems
« on: September 01, 2017, 10:33:52 PM »
I have a 1400 watt generator. I have to run it on half choke for a while before it will stay running with the choke off. I typically top off the tank while it's still running. After I top it off, it often dies or I have to put the choke on half or even full to keep it running. Any idea what the cause can be?
I'm not a tool addict. I prefer "Dedicated Enthusiast prone to bouts of excessive exuberance."
"I love being purple." - Patrick the star fish
Offline john k
Re: Generator problems
« Reply #1 on: September 01, 2017, 10:47:56 PM »
One of two things,  vacuum leak not letting the engine draw in enough fuel, or jets in the carb are getting plugged, requiring more vacuum to pull sufficient gas in.  Quick check for a vacuum leak, around carb base or manifold is to spray a little carb clean, see if the engine momentarily speeds up.
Offline m_fumich
  • Necromancer
« Reply #2 on: September 01, 2017, 11:21:37 PM »
Why would topping off the fuel cause the problem to act up again if either cause were the problem?
Offline john k
« Reply #3 on: September 02, 2017, 04:26:36 PM »
It is just possible that when the tank is filled while running, enough fumes  are drawn in around the carb, that it gets over rich and dies.
Offline m_fumich
  • Necromancer
« Reply #4 on: September 02, 2017, 06:56:15 PM »
I can shut it off to fill it and it does the same thing but not always. I filling it today while it was running and had no problems. Plus, the tank covers everything so it's not likely that fumes affect anything.
Offline skfarmer
  • Chickin killin dawg with more bark than bite
  • Global Moderator
  • Cow crap kicker
« Reply #5 on: September 06, 2017, 05:54:04 PM »
just a wag, not getting enough fuel because of a partially clogged jet or passage. it runs ok when hot but it is cold blooded and when you stir up the tank by adding fuel it is further restricted. i bet the bowl is full of crap.
from the ashes shall rise a phoenix
Offline Aaronlausy
  • Newbie
    • Expert advisor
Generator problems
« Reply #6 on: September 09, 2017, 07:25:03 PM »
This is brilliant Any chance you can add the Arts & Sciences courses to the timetable generator??
I recommend using this forex expert advisor for reliable trading
Generator problems
