Author Topic: Source for durable paint for cement mixer?  (Read 2576 times)
« on: June 18, 2014, 08:48:10 PM »
I'm planning on repainting the cement mixer that I'm working on, and I've heard of "implement paint".  Tried getting some from both Ace Hardware and from Lowes, neither had anything specifically labelled as such, though there were some oil-based paints in "safety colors".
Anyone got a good source?
Re: Source for durable paint for cement mixer?
« Reply #1 on: June 18, 2014, 09:00:34 PM »
All that means is the paint is a heavy enamel. Often implement paint refers to enamel paint intended to be used on farm tractors or
 implements for farm tractors. In reality Rust-O-Leum, Krylon, or other brands often bought in hardware stores or farm supply stores will all work about the same. They are all heavy oil based enamels that are thinned for spraying with mineral spirits, or commonly paint thinner. These days you can increase gloss and paint hardness and durability by adding the proper amount of hardener often sold right near such paint and generally added when the user intends to thin and spray the paint through a gun.
I hope all this helps...........
Offline platypus20
« Reply #2 on: June 18, 2014, 09:18:13 PM »
Damn!! I not really sure if I've ever seen a cement mixer with actual paint on it, everyone I've ever seen looks like it has fallen off a moving truck at least twice.
jack
« Reply #3 on: June 19, 2014, 01:34:29 AM »
True that. WTF does anyone need to paint a cement mixer? If it is just to pretty it up for a sale then slap some cheap paint on it.
« Reply #4 on: June 19, 2014, 02:29:24 AM »
Since I need to work on it and fix some of the deficiencies in the frame, I may as well clean it up and paint it while it's apart.  I'd like it to last another 20+ years sitting in a backyard with only minimal cover...
« Reply #5 on: June 19, 2014, 07:19:13 AM »
How many weenies does it hold?
 needpics
 Needs flames, Hotrod  cement mixer
« Last Edit: June 19, 2014, 07:23:06 AM by pepi »
Self-esteem: Does not make up for a lack of common sense. There is such a thing as a stupid question.
« Reply #6 on: June 19, 2014, 07:57:59 AM »
 needpics
While you are it add some zoomie headers.......... facepalm1
« Reply #7 on: June 19, 2014, 01:18:12 PM »
Powder coat or Dupont Imrom. You could use something like POR 15 but you would have to top coat that. Eastwood make paints for frames and such that are supposed to be durable. You could aslo use a bedliner product.
« Reply #8 on: June 20, 2014, 08:56:31 PM »
I think that I'm going to go with the hardener approach.  Haven't decided on using a paint gun or on brushing or rolling.  The drum isn't easy to clean up and I'll have to probably re-wheel it with something more aggressive to truly bite through all of the rusty buildup.  Don't just want to paint over rust to have it pop the paint.
