Author Topic: Painting with Valspar Tractor and Implement  (Read 4582 times)
« on: August 01, 2014, 09:48:45 PM »
Finally got to picking up some paint for my cement mixer, some Valspar Tractor and Implement paint and the dark red primer.  Also got the VM&P Naphtha.  Directions for spray for the paint seem to indicate mixing 8fl oz to a gallon, which I think means one part Naphtha to 16 parts paint.
There were no spray directions on the primer.
Does this ratio sound right in your experience?  How about the primer?
The MSDS indicates that the Naphtha is nasty stuff.  I'm assuming outdoor application only, if the weather holds...
gotta pick my spray gun up from my folks', dad used it to paint the firewall on his truck.
Offline Scout Driver
  • Scout. Anything less is just a car.
Re: Painting with Valspar Tractor and Implement
« Reply #1 on: August 01, 2014, 10:24:46 PM »
Can't help you with the specific mix, but I'd think that it would be adjusted according to temperature.  I'd also look into a compatible hardener for the paint.
Scott
« Reply #2 on: August 01, 2014, 11:21:48 PM »
see what the Valspar recommends as a reducer. I painted a winch cradle last week with Rustoluem black and used some medium  enamel reducer that I had ,put 3 coats on it and let it sit 4 days. the paint never did "harden up" . it could be scratched/dented with a fingernail. As SD stated look into the hardener too.
« Reply #3 on: August 02, 2014, 12:06:54 AM »
Well, the Naphtha was what was on the paint cans as the recommendation, I'll have to see if I can find anything on the primer, and on any hardeners.
« Reply #4 on: August 02, 2014, 06:57:56 AM »
I made the mistake of using Rustoleum thinned and sprayed several times years ago and finally decided never again, it was like the stuff never dried. I just moved on to other brands myself.
« Reply #5 on: August 02, 2014, 08:23:00 AM »
Hardener is typically use for low temps, I would think the instructions will indicate temp ranges, best advise do not cross manufacture types for paint, it is a chemistry that works together. Yes you may pay a bit more, but the results will be as you wish.
« Last Edit: August 02, 2014, 12:15:12 PM by pepi »
Self-esteem: Does not make up for a lack of common sense. There is such a thing as a stupid question.
« Reply #6 on: August 02, 2014, 12:03:21 PM »
I did find reference to a hardener for this paint, but the local place doesn't carry it.  We'll see.  I'm in no rush, but I wouldn't mind getting the workshop space back either.
« Reply #7 on: August 02, 2014, 12:19:05 PM »
Probably never sells any because it is hell hot there  lolx  Do yourself a favor spray a test panel see what's up, that will tell you the most about the paint, everything else is speculation.
« Reply #8 on: August 08, 2014, 05:00:40 PM »
I've sprayed a few pieces with Valspar. First, get the hardener -- without it, the enamel will be dry slow and soft. Hardener is an absolute with Alkyd Enamel.
For small jobs you can thin with plain lacquer thinner, but for larger jobs get some enamel reducer. Naphtha is recommended by Valspar, but in summer heat it evaporates too fast; leaving orange peel and dry spots. A good slow reducer (check with NAPA for a good enamel reducer) will allow you to put down some wet coats that flow out nicely.
Offline lostmind
« Reply #9 on: August 08, 2014, 05:16:41 PM »
The hardener also helps to smooth out orange peel and give an even gloss. Very hard to get a nice finish on a hot day without it. It usually comes in different gloss levels. The most expensive will give a gloss that looks like it's wet.
Worth the money if you put a lot of effort into something.
Of all the things I've lost , I miss my mind the most.
It's ALL for sale
« Reply #10 on: August 11, 2014, 07:59:55 PM »
Still haven't painted yet, haven't had time.  I'm planning on doing it in the shop with the big door open, in the morning, so that once it's sprayed I can close the door while it dries.  I can cool the shop down easily enough..
I guess I need to order the hardener.
Offline Elroy
  • "Moron"
« Reply #11 on: September 01, 2014, 03:56:17 PM »
Elroy likes Rustoleum Rusty Metal Primer. It sets fairly quick (couple of days) and it sands wells. Their top coats take for ever ( 6 weeks or so) to dry. However they will eventually set hard. The ticker the coat the longer it takes
I met Elroy years ago, I was not at all impressed with him, the guy was like a talking potted plant! A real Moron.
Elroy exists in a demented third person world that is void of Bull Shit and lies.
Offline Pitalplace
« Reply #12 on: September 02, 2014, 05:11:49 PM »
Do not thin the primer. As far as hardner there are some major health concerns so you may want google that. You need a good mask or air supply to spray it.
