Author Topic: Just a Peek  (Read 817 times)
Just a Peek
« on: September 04, 2017, 08:12:51 PM »
The '46 square dial 10EE I bought a year ago that I finally took possession of. It's not set up to use right now. I am the 4th owner. The friend I bought from got it from a nutcase in Arizona in 1995 who rebuilt Porsche engines. It had only done light production before that guy got it. The bed measures 0.0011" wear, which equates to approx 20K hrs use by our best estimates based on other 10EE's. The paint is the 2nd coat and very clean. All covers, misc parts, and original literature are with it. It has a "Works in a drawer" tube drive that runs on 220 single phase. Hopefully I can put it through it's paces sometime soon.
Offline bl00
Re: Just a Peek
« Reply #1 on: September 04, 2017, 08:19:12 PM »
That one is beautiful!  The ones I see for sale online usually look like they came out of the Monarch dumpster.
Re: Just a Peek
« Reply #2 on: September 04, 2017, 09:17:34 PM »
very nice.  thumbsup2
Re: Just a Peek
« Reply #3 on: September 04, 2017, 10:02:52 PM »
Best toolmaker's lathe ever made. Congratulations!! that is truly a beautiful piece of machinery.
Re: Just a Peek
« Reply #4 on: September 04, 2017, 10:24:24 PM »
X2!   I'd love to have one and the place to put it.
Re: Just a Peek
« Reply #5 on: September 04, 2017, 11:16:35 PM »
They are pretty compact. It's 36" to the end of the cross feed handle wide and like 64" long. It is a 3000lb blob of iron to deal with though.
Re: Just a Peek
« Reply #6 on: September 04, 2017, 11:39:06 PM »
I'd probably just injure myself if I had one anyway.  That's what my wife says anytime I wanna buy something...
Re: Just a Peek
« Reply #7 on: September 04, 2017, 11:43:38 PM »
Just wear your safety shoes and you'll be fine. Tell your wife about all the things you could fix and all the dollars you could save by having one. Even if you just use it as a pencil sharpener.
Re: Just a Peek
« Reply #8 on: September 05, 2017, 10:58:36 AM »
Great lathe and I love the beefy tailstock.
Re: Just a Peek
« Reply #9 on: September 05, 2017, 11:50:06 AM »
Monarch was never shy putting iron in tailstocks. Always used a small taper though. This thing has a #2, the series 60 16" at work only has a #4 in a quill that's almost 4" OD. Everything about them is overkill.
I mistyped on the age. It was the very last lathe made by serial number in 1956, not 46.
Re: Just a Peek
« Reply #10 on: September 05, 2017, 12:23:10 PM »
Has the DC rectifier been upgraded, or is it still an old vacuum tube unit?
Re: Just a Peek
« Reply #11 on: September 05, 2017, 01:39:21 PM »
Unmolested vac tubes. It has a slight "miss" for the first half hour or so at low speed, but usually quits doing it after it's warmed up. An electronics guy told my friend it's probably a bad cap somewhere in the drive. I'll investigate if it becomes an issue I can't work with. The lathe came with 6 extra NOS big tubes; it uses 2 in the drive. Also, there is about 20 spare NOS smaller tubes for it.
The tube drive is really an excellent design. It will hold constant rpm much better under load than a new VFD and AC motor, and do it on a plain 220 1ph.
Re: Just a Peek
« Reply #12 on: September 05, 2017, 03:47:16 PM »
Your friend is most likely correct. After 60 years most of the electrolytic caps are leaking -- better to bite the bullet early and replace them all, or you will burn up vacuum tubes in short order. Good luck!!
Re: Just a Peek
« Reply #13 on: September 05, 2017, 08:29:53 PM »
Tha is one nice lathe!
Sent from the twisted mind of the Mudman.
Offline rvannatta
    • Van Natta Forestry
Re: Just a Peek
« Reply #14 on: September 15, 2017, 10:37:33 PM »
the bed could be a little longer so there is space for a deck over part of it..  (grin)
Re: Just a Peek
