Author Topic: The Franzinator assures dry air from your compressor install!  (Read 14396 times)
Online Uncle Buck
Bull;  Since you have the services of a capable master plumber, then I would suggest you build a "Franzinator". Yes, some people have issues with Franz, but his design is truly very efficient, and it will reduce your moisture problems without hanging a massive array of pipe.
Just follow the links and you will find a complete description along with a simple drawing of the design.
http://route60garage.blogspot.com/2009/04/wtf-is-franzinator.html
Offline brockstar
  • "King of Noobs"
  • greenhorn schmuck
Re: The Franzinator assures dry air from your compressor install!
« Reply #1 on: July 26, 2011, 12:36:42 PM »
Warning to noobs - before building one, consider your welding skills first!
I thought about one until Franz cautioned against less skilled welders taking this on.  I'll heed his warnings every time.
Online Uncle Buck
« Reply #2 on: July 26, 2011, 01:05:12 PM »
Great advice!
« Reply #3 on: July 26, 2011, 02:36:36 PM »
Franz also designed a "non-welded" version that can be assembled with commonly available fittings from the hardware store
http://z6.invisionfree.com/ToolBoxTalk/index.php?showtopic=1575
« Reply #4 on: July 26, 2011, 04:12:19 PM »
Couple thoughts. First it would probably work better with a hex nipple in the elbow to direct the airflow straight down. Second using tube instead of pipe for the inlet would allow the use of either a compression or soldered fitting instead of JB Weld.
Offline scooby074
  • I am the Stig
« Reply #5 on: July 26, 2011, 06:48:11 PM »
Do we have to call it the Franzanator?  frustratedx
How about Pneumatic Condensing Water Vapor Reducer? The original's namesake isnt exactly a member in good standing.
« Last Edit: July 26, 2011, 06:52:18 PM by scooby074 »
ambitious but rubbish
« Reply #6 on: December 06, 2012, 06:00:58 PM »
Thanks to member mdlbldrmatt135, we have a great professional drawing of how to make a threaded inlet valve for a Franzinator condenser in case you want to build the non-welded version.
« Last Edit: December 06, 2012, 06:04:34 PM by goodfellow »
Online Uncle Buck
« Reply #7 on: December 16, 2012, 12:17:10 PM »
Ya it should be called the Fanzinator, the guy was a real ass hat but you have to give him his due, he did have some quality know to contribute. Just a damned shame he was such a ring muscle sharing the knowledge or he would still be here I am sure.
So in spite of his being gone and a real true ring muscle you have to give the man credit for the idea he shared here.  thumbsup2
Offline Altec
  • DILLIGAF
« Reply #8 on: December 16, 2012, 12:25:02 PM »
Lol, never knew these had a name. Devices like these are common practice around these parts due to humidity. I've seen poorly laid out systems act more like a garden hose in the summer months.
"Play stupid games, you get stupid prizes."JJ
Offline scooby074
  • I am the Stig
« Reply #9 on: December 16, 2012, 05:58:40 PM »
Actually, the "Franzanator" really an extension on a desiccant dryer or filter , minus the desiccant/filter. There is nothing unique there.  He may try to claim it and stick all kinds of bullshit "copyrights" on it, but its nothing that hasnt been done before. He just plastered it all over the internet and called it his.
Case in point:
« Last Edit: December 16, 2012, 06:04:13 PM by scooby074 »
